LabVIEW simple pendulum simulation
*as i have no clue how to do it
Message 31 of 54
(3,569 Views)
OK, that's 180 degrees different!
  • Do you have problems with programming?
  • Do you have problems with the math?
  • What have you tried?
  • At what point did you get stuck?
Message 32 of 54
(3,544 Views)
How do I make it so the pendulum only goes 180 degrees instead of 360? So far I have managed to get a sin wave that's it
Message 33 of 54
(3,504 Views)
Gravity will limit it to the lower two quadrants, assuming it starts there and the initial speed is zero. (If the initial speed is very high, it can go 360, of course.)
Message 34 of 54
(3,465 Views)
Hi Altenbach, (or anyone else who cares to help)
Do you have any clues why the dampening on my pendulum isn't working? I've attached my file below. Its using the idea that the formula for simple harmonic motion is x(t)=X*cos(w*t)+V/w*sin(w*t) and one of the equations for achieving dampening is Xdamped(t)=Xundamped*e^(-a*t) (where a would be the dampening coefficient).
Also, what's you best advice for a way to implement gravity into the top pendulum?
Message 35 of 54
(3,412 Views)
@Allybruckshaw
Stick it near a mass or some other constant Acceleration field.
Message 36 of 54
(3,269 Views)
This guy...
Such a pedant.
Message 37 of 54
(3,266 Views)
I (and many others!) don't have LabVIEW 2021 yet, so please consider "save for previous" before attaching to widen the audience. (Most here cannot look at your VI and thus cannot tell what you are doing wrong.)
Message 38 of 54
(3,257 Views)
from the file that you posted above, what was the changes that you made?
Message 39 of 54
(2,981 Views)
Hi there so i have started a course assignment for a simple pendulum with damping but my pendulum length doesnt seem to stay the same length would greatly appreciate some help on the matter
Message 40 of 54
(2,905 Views)
