LabVIEW steals communication with external software
Good morning,
I am curently developing a software in LabVIEW and it already operates perfectly as I want.
The whole setup is made up of 4 instruments communicated via USB (VISA).
The problem occurs when I try to run an external osciloscope software (not NI domain) while running the LabVIEW one. After about 1min, the external software loses communication with the osciloscope and says that another program is using the device. Then I need to restart LabVIEW so the osciloscope can communicate again.
No, the osciloscope is not being used by LabVIEW in any way.
And the communication with the osciloscope is being made by USB too.
Anyone knows how to "block" the communication of this COM port to LabVIEW or other solution to this?
Thanks!
Message 1 of 8
(2,711 Views)
@GabrielTo wrote:
Good morning,
Thanks!
Two applications cannot access the same COM port at the same time.  Period.  This isn't really a LabVIEW issue, as much as an OS one.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(2,663 Views)
In one sentence you say you are running both the LabVIEW and the non-LabVIEW oscope software at the same, time, then the next sentence you appear to say this is not the case.  Did I misunderstand something?
Thanks.
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(2,656 Views)
Thanks for your reply.
I am running both softwares at the same time, but they are not acessing the same COM port.
LabVIEW deals with the other 4 instruments while the osciloscope software deals only with the osciloscope.
Message 4 of 8
(2,652 Views)
For the instruments it does use, did you write all of the communication code yourself?  Or are you using some drivers from the manufacturer in LabVIEW, or possibly some DLL or ActiveX?
I ask because some hardware I have seen has manufacturer's drivers that, in an effort to be "easy to use", have some sort of "scan" function that will attempt to send an ID request on all COM ports that exist on the PC and then report back which ones have identified themselves properly.  If any of the 4 instruments you are using have some sort of autodetect code running, that could do it.
Message 5 of 8
(2,638 Views)
Accepted by GabrielTo
After a few tests, i found out that LabVIEW was not the problem.
The problem was with my PC USB hub that when I communicate with the other device connected to it the osciloscope just shut down.
Thanks everyone that tried to help me!
Message 6 of 8
(2,582 Views)
Yet another reason I hate using USB.  If possible, switch to using Ethernet for communicating with external instruments, preferably on a private network.
Message 7 of 8
(2,575 Views)
USB hubs has caused many problems over the years. It seems to be a little better if they're powered ...
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(2,557 Views)
