LabVIEW to Excel - decimal separator issue
I'm using a VI to copy a LabVIEW table to Excel
http://forums.ni.com/ni/attachments/ni/170/125802/1/Write_Table_and_Chart_to_XL.llb
My system uses the comma as a standard decimal separator. Despite changing the LabVIEW settings the table I generate uses a decimal point. When I copy the data values smaller than one are copied correctly, but values > 1 are recognized as the value times a million.
0,9 is still 0,9 but 1,34 is 1340000
Is there any way to resolve this issue
(4,339 Views)
Accepted by NewbieNick
I ran your VI and everything looks fine for me!!
I get the attached table when I ran the code.
Are you using any non-english keybord? or is there any default settings in Excel with formatted cells?
Iam using LV8.5, and I changed the range property's value to Value2 in Set Cell Value.vi (since it had a broken arrow)
Message Edited by Vsh on 11-09-2009 02:55 AM
(4,333 Views)
I'm running Win 7 Pro on a German Sony Vaio and (sadly) with a German version of LabVIEW 9
But how does the keyboard effect the decimal settings, and if it does - do I have to make some changes to my Regional / Language options?
(4,328 Views)
Damn, I just changed system locale and settings to English UK and it works fine.
I don't get it, but it still works!
(4,324 Views)
Yeah,
I had faced a similar issue when I was using an Italian keypad. Period, comas, decimal points are at different locations in different language keypads.
I cant tell you what exactly the problem is,
Im glad it helped you.
Now I am practicing a blindfold typing with an arabic keypad..  :smileymad::smileymad:
Message Edited by Vsh on 11-09-2009 03:12 AM
(4,321 Views)
