ā06-21-2005 02:40 PM
ā06-21-2005 03:36 PM
ā06-21-2005 05:03 PM
ā06-22-2005
07:08 AM
- last edited on
ā03-19-2026
11:29 AM
by
Content Cleaner
@elliot.ee wrote:
Can LabVIEW for Linux wrap around a C++ .so shared library? What would be the correct syntax in the Makefile?
In general, calling a C++ library from LabVIEW isn't a problem. Please check out the External Code Reference Manual for details on the caveats. The most important parts are as follows:
As far as the correct syntax for the Makefile, I'm not sure. I try to avoid directly using Makefiles whenever possible because they frighten me. Fortunately, for me, KDevelop usually enables this behavior.
ā07-01-2008 04:42 AM
ā07-01-2008 07:32 AM - edited ā07-01-2008 07:32 AM
1) To the console. However LabVIEW is a GUI program so unless you attach to the console of a process in some ways from outside you won't see those messages (or probably more accurate but I'm not sure you would see it in the console from which your X Windows manager was started which in most distrbutions is nowadays done automatically).
@yatintyagi wrote:
I too am trying to create a linux library for labview (using the functions in the pvcam library for ccd cameras). There were a few things I couldn't quite understand.
1. what happens when we use printf in the library i.e. where is the text printed in labview
2. when i run a function from the library labview closes. Is there any way to figure out where in the library this happened.
Any help would be appreciated as i am totally lost here.
Yatin
ā07-02-2008 03:28 AM
ā07-07-2008 03:55 PM
