LabVIEW2019 - case structure with wired error cluster changes behaviour!!!
I installed LabVIEW2019 recently and stumbled now over a subject wich could cause alot of work with existing code, converted from older LabVIEW versions.
My existing code with wired error cluster to the selector terminal (which has only the cases "No Error" and "Error") now was converted to "Error 0, Default" and "Error 1", where an error now almost always (except errors with code 1) calls case the case "Error 0, Default", which was intended befor to be the "No Error"- case!
There still is the case "No Error" available in LV2019, but now I have to edit every single case structure in all my projects to work properly in LV2019.
I can't imagine this is intended by NI.
I made a quick search and found for my current project 56 case structures to change...
Greets, Dave
Message 1 of 14
(7,836 Views)
OK, a closer look to the search window brought me to a quick workaround, I replaced all occurrences of "Error 0, Default" with "No Error" and afterwards all occurrences of "Error 1" with "Default".
The replacement worked only with selected items ("Replace Selected") and even not for all of them, so I had to edit them manually. But now it's done. But I have a bad feeling about some not found cases or not some correctly altered case labels.
Greets, Dave
Message 2 of 14
(7,819 Views)
Crossposted here, where the feature is basically announced.
Message 3 of 14
(7,808 Views)
I can't reproduce this behavior, when I take a VI with an error case in LabVIEW 2018 and open it in LabVIEW 2019, I get cases of 'No Error' and 'Error'. Can you post a VI saved in a pre-2019 version that demonstrates the issue when opened in 2019?
Message 4 of 14
(7,781 Views)
Hi Darren,
I made a new VI with LV2018 and attached it.
Opened with my installation of LV2019 the block diagram looks like this:
The other case:
As you can see, the selector label field changes its size when switching to "Error 1", switching back to to the first case now shows the full selector label text. I would consider this a cosmetic problem.
When this VI is run, it shows the following results:
Erro Case-Structure problem - Run - No Error.pngErro Case-Structure problem - Run - No Error.png          Erro Case-Structure problem - Run - Error 0.pngErro Case-Structure problem - Run - Error 0.png
Erro Case-Structure problem - Run - Error 1.pngErro Case-Structure problem - Run - Error 1.png          Erro Case-Structure problem - Run - Error 2.pngErro Case-Structure problem - Run - Error 2.png
And referring to my old thread here I want to mention that I installed LV2019 from the offline installer found here
Greets, Dave
Message 5 of 14
(7,727 Views)
What bothers me is that you don't have an error cluster here, at least from the looks of the block diagram. The block diagram shows the error cluster as "any" cluster as LV did in the old days....
Norbert
Expert: Geometry
Message 6 of 14
(7,711 Views)
Yes, your right. This is intended, I didn't like this "new" mustard-look and deactivated it via the INI- Setting
funkyerrclustWire=False
Got it from here.
There you can see, how long this setting made no problems.
Greets, Dave
Message 7 of 14
(7,707 Views)
Accepted by topic author daveTW
The funkyerrclustWire=False INI token is messing up the feature in LV 2019. It not only affects old VIs opened in LV 2019, but new VIs created in 2019 as well.
I have filed CAR 738644 on this issue. For now, the workaround is to just remove funkyerrclustWire=False from your INI file. Fair warning, we may consider just removing this INI token altogether in a future LabVIEW release.
Message 8 of 14
(7,671 Views)
OK Darren, this solved my problem and I admit, I abused this hiden setting all these years. Maybe that I was the only one in the world.
Thank you all for the Help.
Greets, Dave
Message 9 of 14
(7,638 Views)
I "grew up" with pink error wires, but was happy when errors wires got their own color. Makes code so much more obvious and unambiguous. 😄
Message 10 of 14
(7,622 Views)
