LabView 8.5.1 설치방법
LabView 를 처음 사용하는 사용자 입니다.
씨디가 너무 많아서 어떤걸 어떻게 깔아야 될지 모르겠습니다.
현제는 LabView 한글판 8.5 를깔았고
08년 1분기 8.5.1 디바이스 드라이버를 깔았습니다.
cRio-9002와 NI9853 Hight-Speed 모듈을 쓰고 있습니다.
리얼타임이니 FPGA모듈이니 하는것이 있는데
정확한 사용법을 모르겠습니다.
프로그램하는 방법에 따라 설치 방법도 다를것같은데요
설치하는 메뉴얼이나 모듈설명이 있으면 보내줬으면 좋겠구요
어떻게 깔아야 하는지 좀 가르쳐 주세요...
(4,802 Views)
Please repost in English to get lot of possible replies for ur queries.
Mathan
(4,799 Views)
Let's see how Google understands Korean:
This is the first time you use LabView.  And you need to know what to do with all the installation CDs.
LabView 8.5 is currently available for some device drivers.
I'm not sure about the first quarter of LV 8.5.1.
You are using NI-9853 High-Speed and cRio-9002 modules because you wish to develop real-time FPGA Module, but do not know the exact usage.
You noticed that different programs vary depending on how you do things, such as how to install.
You are looking for installation manual(s) or explanations on how to install everything.
You need help on how to install Labview and how to setup the two modules.
OK..  I will have no clue at how Google will translate this into Korean.. 😉  But here goes in English.
LV 8.5 is available in both CD and DVD formats.  You may use one or the other for your installation.  The DVD has everything onto 1 disk.  The CDs have 3 or 4 disks that need to be installed depending on the version that you have, the features you are installing and the required drivers.  You will also have CD(s) for the two modules.
I would start with Labview. Also make sure you install MAX (Measurement and Automation Explorer).  After they are installed, you can proceed by installing the hardware modules.  Then install the drivers using the appropriate CDs.  Use MAX to verify the configuration (and communication) to the installed modules.
At this point, you are ready to begin programming in Labview.
Good luck,
RayR
(4,793 Views)
I hope Google is good at translating...
Here goes... In Korean:
나는를 사용하여 한국의 구글로 번역. 의 번역을 용서하시기 바랍니다.
8.5 좌심실는 cd와 디스크 포맷 모두에서 사용할 수있습니다. 둘 중 하나를 사용하실 수있습니다 기타를 설치합니다. the dvd은 모든 방면 1 디스크합니다. the 세트는 3 자리 또는 4 디스크를 설치합니다. 버전에 따라 달라집니다 labview the 세트는 당신은, 당신이하는 기능에 필요한 드라이버를 설치하고있습니다. 또한이 cd (들)의 2 개의 모듈 (엄마가 말씀 & ni - 9853).
labview로 시작합니다. 도 설치 맥스 (측정 및 자동화 탐색기). 후에 모듈의 하드웨어를 설치합니다. 해당 세트를 사용하여 드라이버를 설치합니다. 맥스를 사용을 확인할 수있는 설정과 커뮤니케이 션의 모듈을 설치합니다.
설치 후 프로그램을 labview하실 수있습니다.
(4,788 Views)
One thing to add:
After installing LabVIEW, install LabVIEW RT (together with the device drivers)
Ton
My LabVIEW Ideas
(4,768 Views)
