Let's see how Google understands Korean:
This is the first time you use LabView. And you need to know what to do with all the installation CDs.
LabView 8.5 is currently available for some device drivers.
I'm not sure about the first quarter of LV 8.5.1.
You are using NI-9853 High-Speed and cRio-9002 modules because you wish to develop real-time FPGA Module, but do not know the exact usage.
You noticed that different programs vary depending on how you do things, such as how to install.
You are looking for installation manual(s) or explanations on how to install everything.
You need help on how to install Labview and how to setup the two modules.
OK.. I will have no clue at how Google will translate this into Korean.. 😉 But here goes in English.
LV 8.5 is available in both CD and DVD formats. You may use one or the other for your installation. The DVD has everything onto 1 disk. The CDs have 3 or 4 disks that need to be installed depending on the version that you have, the features you are installing and the required drivers. You will also have CD(s) for the two modules.
I would start with Labview. Also make sure you install MAX (Measurement and Automation Explorer). After they are installed, you can proceed by installing the hardware modules. Then install the drivers using the appropriate CDs. Use MAX to verify the configuration (and communication) to the installed modules.
At this point, you are ready to begin programming in Labview.
Good luck,
RayR
