LabView Error Occurred While Installing a Package
I have been attempting to download LabView using the Software Installing platform. The software begins loading, and a few moments later, I receive the message below.
Is there something I can do to work around this?
Thank you.
(1,821 Views)
I was unable to open your picture, and you didn't state what the message said.  If it was something out "Check your Internet connection", this is the generic "Something failed in NIPM and we have no idea what it was" message.
LabVIEW is a complex piece of software, and installing it is something of a challenge.  If you know someone with LabVIEW experience, I recommend asking them for help installing your software.  If you try to do it yourself, don't try to do it "all at once".
Install one version of LabVIEW (I strongly recommend you install 32-bit LabVIEW) with no modules or Toolkits and no Device Drivers.  Install only the "additional" features that you are sure you need.  Reboot.  Repeat, installing one thing at a time, until done.
Bob Schor
(1,769 Views)
