LabView FPGA, morph-ic-II
I'm trying to use LabView with a FTDI chip Morph-ic-II. I use Labview 14.0 and the toolkit Real-Time and FPGA and I installed the D2XX Drivers. However, I can't find my device on the list of the connected devices. Do you have any idea about what i could do ?
Message 1 of 19
(5,318 Views)
...Hu?
Do you have and FPGA?  Is it being used?
If you aren't, and you are just plugging the device into a Windows PC, open the Device Manager and see if the device is recognized by Windows first.  If it is not, then there is no hope for LabVIEW.  If Windows sees it, launch MAX and see if the device is seen there.  If not you may need to install NI-VISA which comes with the device drivers.  Then if that is all good, launch LabVIEW and look at the example finder, I think there is a simple serial read/write that will list the ports detected in a drop down.
Message 2 of 19
(5,290 Views)
The D2XX driver is not supposed to be recognized by any NI tool. You just call it. The vcp driver is the one to use if you want a com port.
Message 3 of 19
(5,283 Views)
We see the device in Windows, in Max. However what is "the example finder", where could i find it ?
Message 4 of 19
(5,273 Views)
Launch LabVIEW and go to Help >> Find Examples and search serial.
Message 5 of 19
(5,270 Views)
The VCP driver is also installed now. Can you explain how i can use my pins of my board in labview ?
Message 6 of 19
(5,268 Views)
Hi Cbernard,
you need to send strings to your virtual COM port (vcp).
Which ones? Read the manual of your FTDI device…
Message 7 of 19
(5,254 Views)
It should just show up as a serial (COM) port.  So you can just use VISA to send and read data.  Again, check the Example Finder.  There is a Simple Serial Write and Read in there that should help.
Message 8 of 19
(5,253 Views)
i'm sorry i'm new with Labview and the FPGA and i don't understand the process that i have to follow. I don't understand why i have to send data with VISA. I just want to have access to my ports on Labview like on this videos : http://www.ni.com/tutorial/14532/fr/#toc2
tanks again
Message 9 of 19
(5,243 Views)
Hi Cbernard,
you connect with your "morph-II" via a VCP, so you need to use VISA to do that communication.
Then you need to use hardware made by NI…
Message 10 of 19
(5,236 Views)
