How to implement if then else?
Hey Friends,
if i want to make a program (if the input is x and L).
if the x is less than -L output must be 0
if the x is between -L and 0 output must be 1
if the x is between 0 and L output must be 2
if the x is more than L output must be 3.
What should be done(since there isnt any if then else commnad in labview)?
Thanks in advance
Regards
Message 1 of 16
(15,338 Views)
The "else" in LabVIEW is the false case
IF x Then (do the True case) else (do the False case)
Just like you nest IF ELSE statements in text based, you also nest True/False cases in LabVIEW
Omar
Message 2 of 16
(15,327 Views)
Thanks..  is there any other way?
Message 3 of 16
(15,320 Views)
The case selector will accept a number.  You can also have ranges for a case (e.g.    0..5 is zero to five).
Check the help on case structures.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/case-structure.html
http://digital.ni.com/public.nsf/websearch/A5D77ADCA661670386256A480062A340?OpenDocument
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 4 of 16
(15,313 Views)
Omar
Message 5 of 16
(15,307 Views)
Your first and fourth rules are both true in this case, but this is a convenient way to test multiple criterion.
Jim
Message 6 of 16
(15,303 Views)
I know you can do this with a formula node.  Not sure how performance compares to other methods.
Message 7 of 16
(15,266 Views)
Thanks for your reply..
cant the range be variable.. like for this case L?
Message 8 of 16
(15,243 Views)
DON'T DO THIS!!!!  There's a note in a style guide, somewhere, that says something ugly about nesting too many Case Structures.  It's tempting, though, and more analagous to If-Then-Else than my first response.
Jim
Message 9 of 16
(15,241 Views)
I did this initially but this did not look nice and was difficult to understand..
cant in place of number a variable be used? like in my example 'L'...
Message 10 of 16
(15,229 Views)
