How to implement if then else?
Yes that will work.
But you can't change the limit value L while running.
Plus if X is a float you will have to think through the type casing to an Int that LabVIEW will do automaticly and set your limits wisely.
Omar
Message 11 of 16
(2,402 Views)
What if i want a variable L in place of 6?
Message 12 of 16
(2,378 Views)
You can't.  Just implement something like Jcarmody showed in reply #6 where you do the multiple tests, convert them to a boolean array which you typecast to a number, that you put into the case structure.
I think the one error he had in his example was that he had L = -2, and by the logic he used and you asked for, leads to invalid results.  L should always be a positive number.
Message 13 of 16
(2,351 Views)
If the Case Structure is "the box" I would think outside of it in this case.
Message 14 of 16
(2,338 Views)
Thank you. I didn't know such a trick (answer n.6 booleean array to number) to avoid multi-nested case.
Message 15 of 16
(2,016 Views)
Today I learned the Step function can literally be replaced with two primative functions (greater than or equal 0 and boolean to 0 and 1).
Message 16 of 16
(1,976 Views)
