LabView FPGA
Hi everyone!
I'm encountering an issue while making pulse width modulation on LabView FPGA using the version 2019 32 bit, with my-RIO.
Currently I'm working with an Example known as :"my-RIO 1900 Customized FPGA.vi" and "RT Main.vi" as its host vi.
In it I changed sine wave generator to square wave generator while adding a control for Duty Cycle but I'm encountering an error while running the code.
The Error is shown below, how to resolve such an issue?
I'll appreciate any help regarding this.
(963 Views)
Hi Sam,
The code is too large after your changes.
The code cannot compiled into your FPGA because it needs too many resources…
Try to optimize your code to reduce the resource usage!
(You forgot to attach any code so we can only give this generic suggestion.)
(950 Views)
The code is too large to be attached. it can come in one SS.
(893 Views)
Hi Sam,
What does that mean?
The VI file is larger than 10MB or 20MB (whatever the file size limit is for the NI forum)?
Even within a ZIP file?
(885 Views)
