LabView Help
 any help would be greatly appreciated I am new to lab view and have no idea where to begin
(1,178 Views)
You need to create 2 random numbers between 1-100, add them together and if it's an Even result, Player 1 wins, else Player 2 does.
Qestit Systems
Certified-LabVIEW-Developer
(1,101 Views)
  • Start with opening LabVIEW and place all mentioned controls/indicators on the front panel. Label them correctly and set the correct datatypes (e.g. Integers for the random number and sum display).
  • Now go to the diagram and implement the logic.
  • How would you create fair random numbers in a define range (fair is important. If the code is sloppy, edge values (1, 100) might only occur ant half the probability of the others.
  • How would you test if a number is odd or even? There are easy and harder ways. Think of the least significant bit!
  • For step 2 you need to repeat the code 10x and you know that number from the beginning. What kind of loop would be most appropriate?
See how far you get and post your attempt once you get stuck. If this is very difficult for you, maybe this course is not for you.
(1,096 Views)
