LabView Linux installation(Ubuntu 20.04)
Hello, I would like to install LabView 2015 SP on Linux( Ubuntu 20.04 ). But I have not seen any manual, example video etc. Is it possible? If yes, how can I install LabView2015 SP on Ubuntu 20.04 computer? Thank you in advance.
(4,802 Views)
HI  OguzKahraman,
Fortunately, there is a way to install LabVIEW 2015 SP1 on Linux. I have attached a link to download it below.
LabVIEW Download - NI
Good luck.
(4,622 Views)
Considering that Ubuntu 20.04 was released in 2020 and LabVIEW 2015 in 2015, it's a lot asked to install that on this Ubuntu system. Linux and Mac are not like Windows, where the system API stays backwards compatible over decades.
In the case of LabVIEW on non-Windows systems you generally want to have a version a little newer than the system on which you want to install it.
Also LabVIEW before 2020 did not officially support installation on Ubuntu, only Redhat based distributions and Suse.
Rolf Kalbermatter  My Blog
(4,608 Views)
@l.hovs wrote:
HI  OguzKahraman,
That's only the runtime installer, not the LabVIEW development system. And I have a feeling that the OP actually has the LabVIEW 2015 installer already and tries to install it on a much more recent Ubuntu system. Otherwise he wouldn't need the 2015 version specifically!
(4,603 Views)
