LabView PDA and Pocket PC2003
I am using Pocket PC 2003 with the LabView PDA.All the documentation deals with Pocket PC 2002. Are there any changes with the Pocket PC 2003? Also I wrote a test application and downloaded to the PDA and that does not seem to execute!Is it bcos of the 2003?
Sprasad
(4,458 Views)
Hi Sprasad,
Please read the following document that addresses your question:
Running LabVIEW PDA Application on a Pocket PC 2003 Device [link removed; article no longer available]
I hope this helps.
Feroz
(4,458 Views)
Hi! Feroz,
Is there a way I can view this document. could you check the link again?
Thanks.
(4,458 Views)
I have exactly the same question. I have LabView PDA 7.0 and a Pocket PC 2003, VIs run ok on Pocket PC 2003 but the problem is when I try to run VIs that call DLLs. The ones that work perfect in Pocket PC 2002 don't work in pocket PC 2003.The DLLs were created using EVC 4.0 SP3.
Are these incompatible?
BTW: the link does not work
(4,458 Views)
