LabView Program for EG&G potentiostat
[ This is a repost of the following article: ]
[ From: "D. Zagidulin" ]
[ Subject: LabView Program for EG&G potentiostat ]
[ Newsgroups: sci.chem.electrochem ]
[ Message-ID: <9icdiq$sbt$1@news.huji.ac.il> ]
Dear All,
I'm looking for LabView program for creates asymmetrical waveforms with
potentiostat EG&G 273A. May be somebody having this program? This will save
lot of my time:)
Thanks in advance
Dr. D. Zagidulin
(4,743 Views)
I did some searches on the web, and I found a few threads in previous info.labview archives (around 1998, I think) that mentioned customers using a LabVIEW driver for this device. I'm assuming they obtained the driver from the manufacturer (EG&G). I recommend you contact them. If not, search the web for "EG&G 273A labview" and you should find some discussion threads in the info.labview archive...if nothing else, you could simply contact the people in those threads and ask them if they still have the drivers.
Good luck, and have a good day.
Sincerely,
Darren Nattinger
(4,707 Views)
hi:I am looking forword to use labview program empolder 273A,but I have no idear,can you give me some advice or examples,thanks!!
(4,304 Views)
hi:I am looking forword to use labview program for empolder 273A,but I have no idear,can you give me some advice or examples,thanks!!
(4,304 Views)
It goes over what drivers will be needed to control the device.
This should help you out.
Aashish M
CEO
TransferFi
www.transferfi.com
(4,270 Views)
