programatically change ranges for RTD's in FP
I currently have a cFP-RTD-122 ( three of them) on and cFP 1800 Module.
I have been able to make good measurements with platinum 100 Ohm, .00385 coefficient sensors. Measuring in the Celsius scale.
I also have been able to use my 120 Ohm, Nickel, .00672 coefficient sensors using a sophisticated vi that one of my co-workers developed. It uses the actual impedence, and converts it into degrees C.
WHat I need to be able to do, is write to the FieldPoint session and programaitically switch between ohms (0-400) and Degrees C in the range category. I founf that one of them is "adressed with a 1B hex, and the other with a 1E hex. I cannot figure out however figure out how to change that configuration via LabVIEW.  Please Help.
Chris
One should welcome adversity as an opportunity to excel.
(2,602 Views)
(2,583 Views)
