LabView Real-Time Startup VI vs Executable
Hello together,
I have a problem which I want to explain with the added picture (LabView Project).
Is it possible to start the VI's "Bilderkennung.vi" and "Bilderkennung_NI.vi" in parallel to "Tubis_WS1819.vi".
So in other words: "Tubis_WS1819.vi" is on my computer. And my target is to start all the three VI's with one click. Is this possible?
Maybe with the Real-Time Startup VI vs Executable?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9mySAC&l=de-DE
Can anybody help me with this?
If you need further information please write it in the comments.
Thanks in advance!
MemberView247
Message 1 of 9
(4,260 Views)
Hi 247,
those other targets need to run before you start your "my PC" VI.
Then you can send a command from your PC to those targets so all targets start to work at the same time…
Message 2 of 9
(4,239 Views)
Hi GerdW,
thanks for your reply.
So I have no possibility to start the three VI's in parallel or maybe in an extra "start sequence"?
I'm looking forward to your reply.
Message 3 of 9
(4,197 Views)
Hi 247,
Sure there is a way!
Have the RT-EXE(s) run at startup of their RT device.
Have them wait for a command, send over the network connection.
When your computer exe starts it sends that command to your RT device(s) so they all can start to process data at the same time…
Message 4 of 9
(4,192 Views)
Spoiler
Hi GerdW,
okay, that sounds very good.
But honestly speaking, I am kind of overstrained with this.
Can you maybe give me a guidance how to proceed step by step?
That would be great.
Thanks in advance!
Message 5 of 9
(4,188 Views)
Hi GerdW,
Thanks in advance!
Message 6 of 9
(4,186 Views)
Hi 247,
Learn LabVIEW (better).
See the example VIs and projects on network communication between PC and RT target.
Then incorporate that communication into your own projects…
Message 7 of 9
(4,181 Views)
Hi GerdW,
that's my target to learn LabVIEW better.
Where can I find this?
"See the example VIs and projects on network communication between PC and RT target."
Thank you!
Message 8 of 9
(4,177 Views)
Hi 247,
example VIs are found via the Help menu in LabVIEW.
Example projects are found when you use the "New…" entry in the File menu…
Message 9 of 9
(4,173 Views)
