converter DINT from plc to show on Labview
Hi
There was one project need converter the PLC DINT data to show on Labview how to do this,use 4 bytes to make a combination?
(3,139 Views)
Hi pi,
The DoubleINT should take twice the number of bytes as your INT…
What does the manual of your PLC tell you about the datatypes?
(3,126 Views)
The PLC send DINT "10000",how to make this combination,how to connection the line?
(3,117 Views)
Accepted by topic author 314159ym
Hi pi,
two different ways for each conversion:
(3,113 Views)
ok,thanks
i will try this way
(3,103 Views)
