converter DINT from plc to show on Labview
Hi
There was one project need converter the PLC DINT data to show on Labview how to do this,use 4 bytes to make a combination?
(3,146 Views)
Hi pi,
The DoubleINT should take twice the number of bytes as your INT…
What does the manual of your PLC tell you about the datatypes?
(3,133 Views)
The PLC send DINT "10000",how to make this combination,how to connection the line?
(3,124 Views)
Accepted by 314159ym
Hi pi,
two different ways for each conversion:
(3,120 Views)
ok,thanks
i will try this way
(3,110 Views)
