LabView Runtime engine 8.2
Hello Community,
My name is Kevin and I´m working at SKF Lubrication Systems Germany GmbH.
I am new at our local IT department at on of my tasks is to substitute one of our PC´s on this PC there is program runing which is called DSWControl and it is based on LabView.
When I start the DSWControl.exe on a new PC there comes an error message which is telling me that the runtime engine v8.2 is required.
The problem is that the employee that programmed this isn´t at the company any more and nobody knows anything about this hole thing.
So I was searching for the right runtime version in the internet, but I always ended at this website here.
But on this website here there are only annual version and not version numbers.
Can somebody help me to find or identify the right version?
Thanks in advance
Regards Kevin
(3,178 Views)
Hi Kevin,
get the license number for your company's LabVIEW license and call your local NI support to help you! (089-7413130)
(3,176 Views)
Accepted by SKFDEBER
(3,170 Views)
Hi UliB,
Thanks a lot for the link, with this runtime engine the program does work on the new PC.
Regards
(3,144 Views)
