LabView and Spider8 from HBM
You may modify the examples so they fit your needs. Therefor you have to understand how the examples work.
Message 21 of 49
(2,850 Views)
That is what I need. I need the "book" where I can learn how the examples work.
Message 22 of 49
(2,836 Views)
Is there any news for this subject ?
Wilfried.
Message 23 of 49
(2,713 Views)
Hello Wilfried,
what Info do you need?
Here's a snippet from my actual code
Message 24 of 49
(2,694 Views)
Thanks Markus for the news.
In fact, I will have to use the Spider8 with Labview. I read in the forum that there's some problems to code a diagram that works fine with the hardware.
So, I would just know if somebody already managed to do something, if yes what are the main errors to avoid, and could somebody give me a piece of code (i'm using LV 8.6.1) that could a start for my application !
FYI, I didn't try yet to use the hbm site's example because I will get the harware next week.
WM
Wilfried.
Message 25 of 49
(2,691 Views)
Hallo Wilfried,
if you give me your Email I can mail you a modified Spider folder for the User.lib. (~1Mb) The Vi's from HBM are based on an old LV-Version and do not Support COM3/4.
LPT works only if you've got standard port adresses (278h, so only onboard LPT)
Message 26 of 49
(2,689 Views)
OK thanks : urabus58@free.fr
Wilfried.
Message 27 of 49
(2,688 Views)
Hello, I have a problem with the VI's from HBM based on an old LV-Version. It is not possible to open these VI. Would somebody have VI compatible with LV 9.0 ?
Message 28 of 49
(2,514 Views)
Hello Fredchorale,
I can mail you a working Spider.llb for LV 9.00
Message 29 of 49
(2,510 Views)
My mail is : frederic.peyrard@wanadoo.fr
Message 30 of 49
(2,506 Views)
