LabView and Spider8 from HBM
http://www.hbm.com/en/menu/support/software-firmware-downloads/data-acquisition-systems/spider8-scou...
This is what i use but is ok just when i log just 2-3 channels and for comunicating with the spider8 i use the paralel cable
Message 41 of 49
(2,061 Views)
Hi!
Thanxs for the answer, but in the link you provide you can find drivers for LV 7.1. I am willing to upgrade my LV installation to 2009, and i cannot find the library to make my Spider8 work.
It looks as if someone has managed to create his own library, so if anybody could please help me and send those files to me, it would get my problem solved.
Thanks for your answer anyway Smiley Happy
Applications Engineer - Certified LabVIEW Developer & Certified TestStand Developer
Message 42 of 49
(2,048 Views)
Hello Jorge,
I' ve tried to communicate to my spider by USB. After little problems I found a VI and changed it a little bit, so now it works with LabView2010 and it recives Measueringdata from the Spider 8. Hope this will help you, too
Message 43 of 49
(2,035 Views)
Hello!
Thanx for your answer, but I am missing some VIs in the one you sent me... could you send me those other VIs? It would be an enormous help!
Regards!
Message 44 of 49
(2,031 Views)
sorry, my fault
so here are both liberies i' ve downloaded. Beispiel2 is the one I changed.
So good luck this time. 😉
Message 45 of 49
(2,025 Views)
Can you help me about to reach the driver for Spider 8 in Labview 8.6? Thanks! My e-mail. acristancho@msn-dot-com
Message 46 of 49
(1,988 Views)
I'm trying to use a Spider 8 with Labview 2011, and I am having some trouble using the drivers. I have downloaded the latest versions here in this thread, and it looks like there is some communication between the spider and LV, but I cannot set up the channels as I want.
How can I define if the channel is a fullbridge/ halfbridge/ thermocouple etc. and how can I set the mv/v setting?
When I try to use the "set chan settings" function, it says it is too old to be converted to current LV version. Anyone have a better library?
Message 47 of 49
(1,933 Views)
Hi, I'm a mechanical enginerring undergrad and I currently have a Spider8 with me. My supervisors assigned me with the task to find out how to connect a strain gauge to the Spider8. I read the manuals and found out that I need to connect outputs like "Measurement signal", "Bridge excitation voltage" and "Secsor circuit" to different pins in the 15-pin socket.
The problem I am facing is that I am unfamilliar with the standard procedure and protocols of connecting these outputs. You see, for example, page D-11 on the manual said to connect the "1 Measurement signal" to pin number 8 wh. Does that mean that ALL strain guages have their "Measurement signal" output at the 1st pin? And once I've connected all the correct connections what do they have a specific software to measure all the strain?
I'm sorry I had to ask this on an NI forum but the email I sent them asking about the situation hasn't been replied to yet.Smiley Frustrated
Do let me know if the description to my problem is unclear. Thanks.
Message 48 of 49
(1,765 Views)
Software Catman from spider for hydraulic ram. Please help me with legend of this icons: What they mean?lllll.jpg
Message 49 of 49
(1,547 Views)
