hi-
I am trying to execute my program in labview, using my cFP-2020. However, it will not recognize my .iak file. When I go to view configuration, it is listed with the correct file path but will not go to the file. It is giving me an error message 32812. I have tried moving the .iak file to a different location and no change. When I execute the program in my RT target, it works fine. Also, everything in MAX works fine. I am using LabView 7.1 with the simple FP write vi. I read through the other posts and could not find anything that would fix the problem.
Curt
