Labview 2009 installation , one of the MS Office Excel VI is broken
After doing Labview 2009 installation , one of the MS Office Excel VI is broken. Tried multiple installations. The same VI is broken and all other VIs work fine. This is happening on only 1 laptop. the broken VI works fine on other laptops.
Message 1 of 11
(3,660 Views)
Does it say why it's broken?  Any info?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 11
(3,659 Views)
Attached is the error..
Message 3 of 11
(3,655 Views)
Try opening this sub-VI to see what the error is specifically.
Message 4 of 11
(3,649 Views)
Message 5 of 11
(3,644 Views)
Accepted by Sayali
Have you tried to search the forum? http://forums.ni.com/t5/LabVIEW/Set-excel-cell-color-and-border-broken-can-t-build-application/m-p/1...
Open the subVI, click on the invoke node that generate the error and reselect the same method, this should get rid of the error (don't forget to save the change once the error is gone.
Ben64
Message 6 of 11
(3,640 Views)
Do you have different versions of Microsoft Office between the computers?
Can you open up that VI and actually show a screenshot of the block diagram where the wire is missing.  (Please attach screenshots as .png file, not embedding them into Word documents.)
Microsoft has a tendency to change some of their ActiveX objects between the different versions of Office including adding or removing parameters from some of the methods.  This will cause VI's to break if they were originally written on a PC with a different installed version of MSOffice.
Message 7 of 11
(3,639 Views)
Thanks for the link to the other forum.
I followed the solution from Darth_Vader_DK at http://forums.ni.com/t5/NI-TestStand/Report-Generation-broken-after-deployment-Excel-Set-Cell-Color/...
Thank you!
Message 8 of 11
(3,613 Views)
Thank you!
And...Did you fix your problem?  If so, please provide feedback to your solution.
Message 9 of 11
(3,611 Views)
Yes, the problem os fixed. The VI is no longer broken.
Message 10 of 11
(3,609 Views)
