Labview 2015, Excel select data within the range to the Work Sheet.
Hi, guys.
    I have a question about deal with data in Excel,
    I had determine two cell's address(eg A1, C20), then select the data(eg. within A1 to A20 and C1 to C20) to other sheet(or table).
   Thx.
Message 1 of 11
(6,410 Views)
Is your requirement is to copy contents of specified range from one sheet to another sheet?
how do you want to achive that? 1.ActiveX 2.Report Generation ToolKit
Message 2 of 11
(6,406 Views)
PalanivelT 已写:
Yes, one sheet to another sheet, other I want to use ActiveX.
Message 3 of 11
(6,399 Views)
Please find the attached Files, I am working on it to create a excel using activex for all the sceanarios but its in progress
but it is sufficient for your requirement i hope.
Message 4 of 11
(6,391 Views)
PalanivelT 已写:
Thank you, Palanivel T, I try to use the files to solve my problems.
Message 5 of 11
(6,388 Views)
Its an single run VI you need to call the same  VI sequentially by providing options in proper order.
Open Excel
Create Workbook
Open WorkBook  etc.,
Close Ref once your job is done.
Message 6 of 11
(6,385 Views)
@Erbin wrote:
PalanivelT 已写:
I'm guessing that you don't have access to the Report Generation Toolkit.  To do what you propose is pretty simple using the RGT ...
Message 7 of 11
(6,353 Views)
Accepted by topic author Erbin
There is no need to import the range value to LabVIEW and then to write it back to Excel if you use the Range.Copy method. Here's how to use this method (I used the RGT vis to open Excel and to get the Excel.Application ActiveX reference, it was faster to validate the code of interest)
Ben64
Message 8 of 11
(6,335 Views)
Hi, there is a easier way to do get the data you want: just use Excel Get Data.vi in the RGT->Excel specific. You just need to specify the start cell and the end cell.
Message 9 of 11
(6,320 Views)
That's easier if they want to purchase a license.  It sounds like they don't have access given they stated they wanted to work with ActiveX over the RGT
Message 10 of 11
(6,314 Views)
