Labview 2015 SP1 " error 3. Could not open front panel / Not enough memory resources
Has anyone come across this error with Labview 2015 SP1 and found a solution?. VI appears corrupt or something. Unable to open it.
[BADGE NAME]
(3,346 Views)
Or there is a code problem. Are you using any XControls? You need to post the VI. Without the VI all we can do is guess.
If the VI is corrupted you will need to restore a copy from your backups -- you are backing up your code, right?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,327 Views)
I am not using any Xcontrols. The VI cannot be opened so I am not sure posting it will make a difference 🙂
The error message is "Labview error 3. Can not open front panel." Then another error dialogue says " Bot enough memory resources...."
Does not look like I have a back up but will redo the vi as a last resort if I that's what it comes down to.
[BADGE NAME]
(3,322 Views)
Then start redoing. And set up a process for backing up your code. SVN and an external USB harddrive is better than nothing.
Mike...
LabVIEW Champion
(3,317 Views)
You are right. Those are essentially the reason I can even think of redoing it. 🙂 Because I back up about twice daily.
[BADGE NAME]
(3,314 Views)
