Labview 2015, some Excel Sheet data move to other Excel Sheet
Hi, guys.
    I want to achieve functional about data transfer between Excel Sheet.
    E.g. I obtain a cell's address, then the data in the address move to other Excel Sheet a particular cell.
    what can I do? thanks.
(3,456 Views)
Its Quite Possible.How do want to achieve this?
1.Report generation toolkit
2.Accessing Excel Fuctions using Activex
(3,437 Views)
Thank you, PalanvivalT.
I wish you tall me the two ways. I need to contrast and choose a adaptive one.^_^
PalanivelT 已写:
(3,425 Views)
Accepted by Erbin
Report generation Toolkit has buit in VI which you can use for your requirement to done, but its an add on toolkit for which you need separate Licence.
ActiveX Doesnt requires External Toolkit, but need to create your own LabVIEW Code using Properties and Methods.
look at this thread which will be useful to create Custom code using Activex.
http://forums.ni.com/t5/BreakPoint/Excel-Board/m-p/379682/message-uid/379682#U379682
(3,415 Views)
Hi, you can do this using Excel get data.vi & Excel Easy Text.vi in the Report Generation Toolkit. You can specify the cell with both two vis.
(3,341 Views)
