Labview 2021 expression node bug
Hello everyone, I just updated my development environment to LabVIEW 2021, and I immediately noticed my application does not work as expected. I found out that U64 implementation of Expression node function does not work properly (see the snippet below).
Message 1 of 11
(5,141 Views)
Can you provide examples of input values and expected/unexpected outputs?
Is it a problem of the U64 datatype or of all those coercion dots in your snippet?
Don't forget the different amount of mantissa bits in the U64 and DBL datatypes in your code!
Message 2 of 11
(5,135 Views)
I'm guessing it has something to do with the Economists rounding LV uses (or whatever it's called).
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 11
(5,105 Views)
You mean it used to work and now it doesn't?
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(5,087 Views)
Thank you all for your prompt replies. I wanted to attach the entire VI containing proper default values, but for some reason I went for a snippet. Please see the attached VI, everything will be clear.
Message 5 of 11
(5,060 Views)
Still not clear on my phone.
  • What are the I/O values?
  • What is the representation of "2"
The expression node will use "Bankers Rounding" so expect only even values in the U64 out.  And the 2 in that is likely signed forcing an insidious coersion.
Message 6 of 11
(5,054 Views)
looks like 37497077760 is truncated to 2147483647
Message 7 of 11
(5,046 Views)
Looks like the expression node Coerces to 32bit not entirely unexpected.
Message 8 of 11
(5,037 Views)
Too late to edit.
The expression node predates the introduction of the 64 bit integer datatype.  Since it never had an overflow output I can't imagine breaking the backward compatibility by supporting 64 bit inputs.
Coercion dots or a compiler warning would be nice though.
Message 9 of 11
(5,017 Views)
We just ran into this.  It worked with LV 2018.  I just checked LV2022 and it seems broken there too.  Is this going to be fixed?
Message 10 of 11
(4,788 Views)
