Labview 3.1 file
Does that mean 3.11 is still supported since it is on the ftp site :) -AK2DM
Message 11 of 13
(1,027 Views)
The update from 3.1 to 3.1.1 was the 1st I found on the ni page,
and yes its the student edition (LVSE).
I got access to another floppy disk set, but not luck on installing it on XP Pro (with SP3) yet.
Could not open the file named: ...
disk1
ZADVD.LL_
disk2
DSP.LL_
disk3
DAQ.LL_
disk4
LVSE.EX_
It seems that the floppies are gone to the floppy heaven.
So toying a littel with LV 3.1 will not be awaylabe for me.
Now the next issue you might be able to help.
It's about LabWindows for DOS 2.2, I don't get it running in the DOSBox,
the floppies are fine, the installation works too, but LWfD will not run.
Did somebody has a clou to solve this riddel?
Message 12 of 13
(1,013 Views)
Hi chatnick,
Windows XP is only compatible with LabVIEW versions 6.1 and later, as seen in the Windows Version Compatibility with LabVIEW KnowledgeBase.  I hope this saves you some time and energy!
- Greg J
Message 13 of 13
(1,001 Views)
