Labview 5.0 and NiDAQ 6.7 driver issues
Labview 5.0 and NiDAQ 6.7 driver issues.
Hi there,
I am using Labview 5.0 and NiDAQ 6.7 on four older test computers (Win2000), each with two DAQ cards, PCI-MIO-16E-1 and AT-DIO-32F installed. Three of the systems work fine, but one is not. I am able to swap out one of the hard drives, in an attempt to rebuild the fourth hard drive in one of the good computers. I started with a clean hard drive, and upon installing NiDAQ, I get DAQ card drivers issues, which can lead to “blue screen of death”, or the system reboots !?!
cheers
John
(2,655 Views)
Accepted by jahrichey
Can you post back with some more information on the exact error message you are seeing
Regards
Richard S
Applications Engineer
Certified LabVIEW Associate Developer
National Instruments UK&Ireland
(2,636 Views)
Hi Richard S,
I am waiting to gain access to the computer again, but from what I remember blue screen said the file "nipalk.sys" was not loading.
Can you tell me if NIDAQ 6.7 has the correct Win2000 drivers for these two DAQ cards, PCI-MIO-16E-1 and AT-DIO-32F, as have been struggling to install the drivers! Have just downloaded the NiDAQ 6.7 to eliminate any possible CD error.
regards,
John Richey
Test Systems
Tel. no. 028 9046 5688
SYSTEM
Hardware
PCIMG 1.0 board - PEAK SBC760VL2 Rev. C
Backplane – ATX6022/13L Rev. A3-RC
RAM – 512MB
Hard Drive - WD SATA 500GB
EISA DAQ card - AT-DIO-32F
PCI DAQ card - PCI-MIO-16E-1
Software
OS – Windows 2000 SP4
Labview - 5.0.1
NiDAQ- 6.7.0f6
(2,628 Views)
