Labview 5.1 6 6.02with nidaq 6.5.2 and 6.8 problem
I am still using oldies AT MIO E 10 and until recently Labview 5.1 with NI
Daq 6.5.2.
I swtiched to Labview 6.o last week to recompile my Vi's developed in
Labview 5.1.
I had to reload Ni daq 6.5.2 over the default ni daq 6.8 of Labview 6 to run
may app with
a AT MIO E (10 or 2). Fair neough since NI says that AT cards are not
supported even with 6.5.2 (my experience with intricate parralel running
counter and dacq circular buffers shows that AT still run properly with NI
DAQ 6.5.2.)
It worked fine until I sent them abroad without diagram first anf then
with diagram and password.
It could not be recompiled there.
Last Friday, I loaded the setup to upgrade Labview 6.0 into 6.0.2 from NI
site, thinking tha
t maybe the probelm was caused by 6.0 not being upgraded.
The program worked again provided I reloaded NI-DAQ 6.5.2 first.
Now I wanted to uninstall Labview 6.0.2. Impossible!
Could you tell me why?
I also noticed that starting my PC NI Daq wanted to be configured properly.
I never had a chance to quitt a dialog box. I stalled. I smashed it and
could still use my application with AT MIO E 10.
Could you tell me what went wrong? Can I trust this upgrade? Prior to this
upgrade to 6.0.2 I could unistall Labview 6.0.
Very annoying.
Gérard
(2,556 Views)
One thing you might try is to install the 6.0.1 patch over the 6.0.2 patch. Then, try to uninstall LabView from Add/Remove Programs.
The link to the 6.0.1 patch is:
http://digital.ni.com/softlib.nsf/websearch/980AD52E695EBD09862569AC007B027A?OpenDocument
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,556 Views)
