Labview 8.2 program gives error in Labview 8.5
Hello!
I am trying to run a program that has been written in Labview 8.2 in my Labview 8.5. But I get the error that you can see in the attached snapshot. I wonder if this is a compatibility issue?
Thank you.
(3,053 Views)
Hi rayt,
wire something to all the inputs on the call library node and it should be executable. I don't know if this behaviour is different from LV8.2.
Mike
(3,041 Views)
You mean to say you are able to run this in 8.2 and not in 8.5? You will have give some description about the library node and as mike suggested did you try connecting some value to all the inputs?
(3,038 Views)
