Labview 8.5 and DDE Vi
Hi.
Im using LV8.5, but I am not able to find some DDE Vi, like DDE Advise Check and other related.
Doenst LV8.5 support anymore those?
I can find just DDE Open, Request and Close.
Thank you
Antonio
(2,788 Views)
Accepted by Yixiao-uncle
All of the DDE VIs can be found in the LabVIEW install directory in the vi.lib\Platform\DDE.llb library. You can add this library to the palette by simply customizing your palette.
(2,784 Views)
