Labview 8 ClearCase problem
I'm using Labview 8 with ClearCase SCC. Initial setup-up went OK. But after two days Labview does not connect anymore to the ClearCase server. After reinstallation of Labview 8 it was again possible to connect to ClaerCase. But again after 3 days LabView does not connect anymore to ClearCase. Also reconfiguring the ClaerCase connection in Labview does not work.
Does anyone know more about this problem and how to resolve?
Are there anywere inifiles which could be hacked to solve the problem?
Attached is also screenshot with the error message.
Bert
(2,993 Views)
Hi Bert,
i had the same problem.
My solution was to remove the ClearCase settings in the labview version control dialog. Then i close and restart labview, set the previous ClearCase settings and load my project file. Since that time my ClearCase connection running without any problems.
Indeed, this isn´t the ultimaive solution but it´s effective.
greetings,
Bernhard
(2,958 Views)
Hi Bernard, This solved indeed my problem. An additional fact was that I had to follow your procedure from the main Labview window and not from the project explorer as Labview then hangs. Thanks a lot. Bert
(2,945 Views)
