Labview 8 application for Labview 6
I converted a Labview 8 .vi file to an exe application however when I tried to run it on a different computer that only has Labview 6, it didn't work.  The error was that the .exe file is only compatible with Labview 8.
What do i need to do to convert my Labview 8 .vi files so that I can run it on the other compuber with only Labview6?
Thanks!
(3,281 Views)
You need to have the LV8 run-time installed on any system that you want to run an executable built with LabVIEW 8. This is just like you needed to have the LabVIEW 6 run-time installed to run an executable built with that version. If you choose to create an installer when you do the build, the installer will include the correct run-time and put in on the system along with the application.
(3,268 Views)
You need to install the LabVIEW 8 runtime engine on the new computer.  It can be downloaded from here.
Jaegen
EDIT:  Oops - Dennis beat me to it. Smiley MadSmiley Very Happy   Well, you can use the link I posted at least.
Message Edited by Jaegen on 09-28-2006 12:10 PM
(3,267 Views)
Thanks!!!!!
(3,258 Views)
