Labview 8 problems
When I go to open labview 8.0, I get a bunch of subvis loading. Many are missing and I have to skip them. These vis load for a couple of minutes, and then labview opens a new vi. If you close this vi, another one appears and you cannot close labview unless you end task. When installing labivew, i had an mib.cab file missing and I'm not sure why. Any explanation or help is appreciated.
(2,810 Views)
Have you tried to simply repair the installation?
(2,799 Views)
