Labview COM interface
Recently I have a challnging task of writing a COM component that would be used by LabVIEW.
Everything is fine except the speed.The interface includes passing large arrays.
I have tested and the "VARIANT -> SAFEARRAY" way gives the worse performance.I also tried
using "Flattern to String -> BSTR" way, this was a twice faster  but still very slow.
Just to say some numbers, I am passing an 1024x1024  double array. The fastest result till
now is 75 milisecond.So I am wondering, is there a way to pass just a pointer to array, like
in usual DLL ?
Michael.
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(4,007 Views)
There is a section on this document that discusses passing arrays via ActiveX calls. Does this address your specific issue? Are you trying to pass a pointer out of LabVIEW?
https://decibel.ni.com/content/docs/DOC-9080
Ravi A.
National Instruments | Applications Engineer
(3,971 Views)
Ravi,
Thank you for replay, I have passed over the document,but didn't found any ActiveX part.
May be I am missing something..
Michael.
(3,945 Views)
These are Function Nodes that call DLLs. You can try to call a DLL and pass the pointer to that DLL, and from there move it to where you need in your code.
Ravi A.
(3,921 Views)
