03-29-2012 04:49 PM
I would like some help on a programming issue:
I know how to read whole excel data sets but how do you read two points at a time? I would like to extract a number from row 1 column 1 and row 1 column 2. I will use these numbers simultaneously as for loop counters. Then the program should read row 2 column 1 and row 2 column 2. This pattern should continue (number of times unknown) until the two numbers both equal 0.
Please help me with any suggestions you have.
Thanks ahead of time!
03-29-2012 04:58 PM
Hi mtcellar65
1. you know how to read the whole excel data - just read the 2D Array (whole information)
2. extract the single elements using 'Index Array' Function.
the index for row and column can be kept in a shift register.
3. increment the indices and repeat step 2 again
hope this helps
Renn
