Reading two data points at a time in Excel
I would like some help on a programming issue:
I know how to read whole excel data sets but how do you read two points at a time?  I would like to extract a number from row 1 column 1 and row 1 column 2.  I will use these numbers simultaneously as for loop counters.  Then the program should read row 2 column 1 and row 2 column 2.  This pattern should continue (number of times unknown) until the two numbers both equal 0.
Please help me with any suggestions you have.
Thanks ahead of time!
(2,184 Views)
Hi mtcellar65
1. you know how to read the whole excel data -  just read the 2D Array (whole information)
2. extract the single elements using 'Index Array' Function.
 the index for row and column can be kept in a shift register.
3. increment the indices and repeat step 2 again
hope this helps
Renn
Kudos always welcome for helpful posts 🙂
(2,183 Views)
