Labview, Change the phase between 2 signals dynamically
I'm working on a big VI , and for testing my VI I have some controls.  A part of my VI is to generate 2 sine signals with the same amplitude and frequency and a phase difference between thoses 2 signals.
My example is quite simple but very similar the one I use :
- I can change frequency and amplitude while the VI is running.
- I can't change the phase.
Anyone have an idea ?
thank in advance 😉
Message 1 of 8
(6,716 Views)
HI,
I looked in help and there is written: "Phase (deg)—Initial phase in degrees of the waveform. The default is 0. "
So, I think that you are able to set phase only before VI's start.
Simyfren
Message 2 of 8
(6,700 Views)
Thank you for your rapidity, I had only look with the CTRL+H view  ..
Do you have an idea for increase this value during the run ?
I have tried sinewave generator but it work like the "simulate signal" ..
Message 3 of 8
(6,692 Views)
Try to use block "Sine".
Here is small example:
Hope this helps!
Simyfren
Message 4 of 8
(6,684 Views)
Hi Simyfren,
I have try your solution but it doesn't give anything usable for me..
I have also tested a lot of stuff but nothing comes good.
If anyone have an idea, he's welcome 🙂
Max
Message 5 of 8
(6,596 Views)
Max,
When you say nothing useful, do you mean the VI did not run? Or, do you mean it runs but does not behave the way you want it to?
Dan
Message 6 of 8
(6,584 Views)
Hi Danl_B,
My VI run, but I haven't a sine at my output. if I use a graph chart I can see a sine (not really good in résolution, it's more like a triangle) .
And if I set this signal for my DAQ analog Output and after that Acquiring with an other DAQ, it doesn't show me a sine but a square with strange change of amplitude.
I hope you can understand what I mean, my english is poor..
Max
Message 7 of 8
(6,563 Views)
Accepted by MaxLamb
I have find the solution :
I have set the input "reset signal" of Simulate_signal.vi with a constant TRUE. And with that it works fine !
Sorry for being a noob 😉
Hope this will help someone else.
Message 8 of 8
(6,556 Views)
