Labview Cluster and grouping help
Here is what i need to do..
Use a for loop to build a cluster as shown in the following figure. The cluster has 3 inputs: a floating-point real number, an integer, and an array of numbers generated by the far loop. The output is wired to a waveform graph to display the random numbers
it tells me to do this Image of 3-input cluster and output waveform chart in LabView
However i can not figure out how to get the cluster, graph and group to be able to connect. Is there something i need to do inside the cluster? heres what i have so far..
(2,963 Views)
(Posting by phone, cannot see vi)
Make sure the elements are wired in the correct cluster order. Array at the bottom.
(2,958 Views)
Accepted by Roupaz
Just connect the wire to the waveform graph output and it works.  To make the cluster, right-click the wire and select "Create → Indicator".
(2,945 Views)
Yes, even if the wire to the graph terminal is valid, all branches will break if the cluster indicator is wrong. This idea hopes to fix that. 🙂
Make sure you understand cluster order and how to change it.
(2,935 Views)
