Labview Community to full Labview
I need to transit from "self learning" Labview Community 2020 to Labview (paid version) for work.
If I need keep as much as possible, what shall do ? (i.e. what uninstall and what to be installed)
Is there some constrain moving from Community 2020 to LV 2021 ?
Thanks you
(1,995 Views)
Accepted by KPr_HW
If you paid for LabVIEW Professional (there are 3 paid versions, home, full and pro), I think you only need to change the license.
Probably a matter of deactivate and activate with a new serial nr.
The LabVIEW Full version doesn't have all features.
Just hard disk space...
(1,967 Views)
This is a VERY tricky legal maneuver, one that you should be consulting your company's lawyers about.  Having Community Edition alongside one paid for by the company will make it almost impossible for the company to distinguish which license was used for what programming, and this could make for messy conflict of interest issues.
To be safe, I completely partition my work stuff from my personal stuff by developing my personal stuff on a personal computer.
Bill
CLD
(Mid-Level minion.)
(1,944 Views)
Accepted by KPr_HW
You can't have two versions* next to each other, and that wasn't the question.
LabVIEW Community Edition and LabVIEW Professional is the same software, only the license is different.
So, change the license.
* You can (technically) have a community LV20 and a pro LV21, or maybe even a community LV20 32 bit and a LV20 pro 64 bit.
(1,939 Views)
Yes, but I was just trying to potentially save someone some legal headaches by advising against doing it at all.  It's better to avoid the issue entirely than have to explain what you are doing to the legal department.
Bill
CLD
(Mid-Level minion.)
(1,931 Views)
