Labview Crash when call keras function using python node
Hello everyone !
I call the python keras based Neural network model in LabVIEW 2018 using python node but  the LabVIEW crash when i include the keras function in it otherwise the other python codes working fine in it.
Specifications:
1- windows 7 (64 bit)
2- LabVIEW 2018 (64 bit)
3- python 3.6.0 (64 bit)
4- keras 2.6.0
5- tensorflow-cpu 2.6.0
kindly suggest me the solution to resolve this issue. 
(4,237 Views)
why windows 7?
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
(4,156 Views)
Hello jay thanks for reply
 we try it on windows 10 and 11 but same issue occur. code working fine on VScode and python shell ,cmd but i call it on labview python node, labview crashed.
(3,904 Views)
Accepted by topic author Aht22
Can you try calling the python code directly not from a python node? You can try this ( put in your code path and name):
This will use whatever python is loaded to your system PATH variable for python so you can use whatever version of python you want. You can also pass in variables as args and kwargs.
(3,890 Views)
thanks jay for your help.
this is work for me
(3,867 Views)
