Labview Evaluation software Setup problem. "merged.bin" missing. Help!
I tried installing the Labview 7 Evaluation software that I downloaded. A file named "merged.bin" seems to be missing. First, when I opened the setup.exe file, I got an error message that "merged.bin" has not been found. Then I saved a blank Notepad file as merged.bin and re-ran setup.exe. The installer started running but I got the following error message:
K:\NIInstallers\dev\1.1.1\src\UberInstaller\IniFileInfo.cpp(982): IInstallerError 11002
Fatal Error. Failed to open handle for E:\LV_70_EVAL\supportfiles\merged.bin.
Failed to open install session for E:\LV_70_EVAL\supportfiles\merged.bin.
Msi Error: 1620
Error Record:
Exception code: E06D7363 ()
Fault address: 77E99282 0001:00038282 C:\WINDOWS\system32\kernel32.dll
Registers:
EAX:00CDF1E0
EBX:0000000A
ECX:00000000
EDX:0000000C
ESI:00CDF270
EDI:00CDF270
CS:EIP:001B77E99282
SS:ESP:002300CDF1DC EBP:00CDF230
DS:0023 ES:0023 FS:003B GS:0000
Flags:00000206
Stack Trace
Address Frame LogicalAddr Module SymbolName + Offset
77E99282 00CDF230 0001:00038282 C:\WINDOWS\system32\kernel32.dll RaiseException + 81
004C0050 00CDF270 0001:000BF050 E:\LV_70_EVAL\setup.exe
0041E86E 00CDFA64 0001:0001D86E E:\LV_70_EVAL\setup.exe
004474DD 00CDFA78 0001:000464DD E:\LV_70_EVAL\setup.exe
00440B1D 00CDFC48 0001:0003FB1D E:\LV_70_EVAL\setup.exe
004409A6 00CDFCE0 0001:0003F9A6 E:\LV_70_EVAL\setup.exe
00461D74 00CDFD84 0001:00060D74 E:\LV_70_EVAL\setup.exe
00461E56 00CDFDA8 0001:00060E56 E:\LV_70_EVAL\setup.exe
00468F71 00CDFDF0 0001:00067F71 E:\LV_70_EVAL\setup.exe
0046902E 00CDFF18 0001:0006802E E:\LV_70_EVAL\setup.exe
004E7EF3 00CDFF80 0001:000E6EF3 E:\LV_70_EVAL\setup.exe
004C5C6D 00CDFFB4 0001:000C4C6D E:\LV_70_EVAL\setup.exe
77E765DA 00CDFFEC 0001:000155DA C:\WINDOWS\system32\kernel32.dll lstrcmpiW + 152
Please tell me what to do. I am a student and am working on a project. I desperately need to use this sofware. Thank you very much and Happy New Year!
Message 1 of 22
(5,665 Views)
I'm guessing that the download is corrupt or incomplete. What's the size of the downloaded lv70_eval.exe?
Looking at the file properties, mine is 172 MB (180,694,594 bytes).
Message 2 of 22
(5,659 Views)
The size is 172 MB (180,694,594 bytes). What exactly does the file "merged.bin" contain? Can you please open merged.bin in your LV_70_EVAL folder, copy the whole text in it and paste it in your next reply? I will make the file myself! Or much simpler: Send me the file itself as an attachment. Thank You!
Message 3 of 22
(5,654 Views)
>Can you please open merged.bin in your LV_70_EVAL folder, copy the whole text in it and >paste it in your next reply? I will make the file myself! Or much
Hmm, most probably this is not a text file but a binary instead.
Rolf
Rolf Kalbermatter  My Blog
Message 4 of 22
(5,647 Views)
Merged.bin is a ~26MB binary file. I don't think that substituting another merged.bin would solve your problem. Most likely the error message is just an indication of a bigger issue. Something got scrambled somewhere and you need a good copy of everything. I would also highly recommend to scan your hard disk for errors, including a surface scan. Do you have enough disk space? How fragmented is your disk?
Message 5 of 22
(5,643 Views)
Another possibility: Do you run an updated antivirus? First (1) do a virus scan, then (2) disable the antivirus while extracting and installing the LV-eval version.
Message 6 of 22
(5,641 Views)
I use Trend Micro PC-cillin Internet Security 2005 and it's updated. I ran a virus scan and didnt find anything. I think you are right. Something must have happened during the download. Anyway, I'm re-downloading it.
Message 7 of 22
(5,623 Views)
Hi
Am unable to download the Labview 8.5 evaluation from the ftp link provided, the exe has been removed i suppose.
can anyone confirm and update NI about this.
Arun
Message 8 of 22
(5,204 Views)
This thread is over 3 years old and talks about LabVIEW 7.0, so it is not clear what you are referring to.
To download LabVIEW 8.5 evaluation, please go to the following link:
[link removed]
Message 9 of 22
(5,202 Views)
Oh, sorry about that,
but i was reffring to the evaulation 8.5 version, the link is broken i belive.
Message 10 of 22
(5,196 Views)
