Labview Excel Search data in one column and send back data from the second!
I am still very new with using LABVIEW and I have a issue. I am using an excel worksheet with two columns and four rows. In one column I have  barcode numbers and in the second I have which sequence tests that the particular barcode has with it. I have it where I get the barcode scanned but what I need help with is having Labview search the excel sheet for a match on the Barcode (From column one) and return back the related test sequence that goes with it ( From Column two). Any suggestions???
Joe
(4,496 Views)
Thank you for you quick response! I was reading through the discussion you sent me however I need to search for a cell in one cell to determine what cell to read from in the other column. I attached what I have done thus far! I also attached the excel sheet that I am reading from. I search column B for the Barcode and need to send back its corresponding cell in Column C! I can get the program to find the barcode in column B in the excel sheet but I can't get it to show the the corresponding cell in Column C! Any and all help will be appreciated!
Joe
(4,462 Views)
You forgot the attachment
(4,460 Views)
Sorry!
(4,455 Views)
This is from memory but I think that to use the vlookup function the value you search has to be in the first column. Try swapping columns A and B. Note that the first row and columns seem useles since they are just replicating the row and column headers, you could probably delete them.
Ben64
(4,448 Views)
Your vi is suffering from a lot of issues, to begin with first put a wait function in the while loop so it doesn't run as fast as possible. You should also have a look at the state machine architecture. Finally, you should open Excel once when you start the vi and quit Excel only when you stop your vi.
Ben64
(4,445 Views)
