Labview FPGA NI-7854R
I am trying to implement I2C and Parallel Communication protocols. Can anybody help me with example code specifically for NI-7854R.
(3,057 Views)
SPI and I2C Driver API
GCentral
(3,052 Views)
I've personally used this before, and it works quite nicely:  https://forums.ni.com/t5/Example-Code/I2C-Bus-Communication-Example-Using-LabVIEW-FPGA/ta-p/3996143/...
Just download it and follow all the instructions to get the FPGA code compiled and the Host updated.  (Its pretty detailed, with pictures, and relatively easy to follow.)
I attached an example on how to call the Host in a wrapper VI to do basic I2C communication (this was curtesy of a NI Applications Engineer who emailed this to me when I first requested help with the library):
If you decide to use this and have any questions, just let me know!
If someone helped you out, please select their post as the solution and/or give them Kudos!
(3,046 Views)
Hi
(3,022 Views)
