Labview FPGA : The compilation failed due to a Xilinx error
While using FPGA module in LabVIEW to generate a sine I have encountered the following error.
LabVIEW FPGA : The compilation failed due to a xilinx error.
Details: Error : [Common 17-214] No license to run PlanAhead.
I have attached the error screenshot and the VI.
(3,100 Views)
I'm sure I had this a few times, and I think the problem was that the virus scanner was locking the FPGA files during the build.
I'm not sure, but try to exclude the FPGA directory (in the root of C:\) from the virus scanner. It just might work.
(2,946 Views)
