Labview Graph Issues
I have fixed this issue in the past, but not with a filter on. When I run my VI the graph polts my data from right to left. How do I change it to plot from left to right? I have tried switching the array inputs to no avail. Any suggestions? I am fairly certain it is an easy fix, but with my limited LabVIEW knowledge I have run out of ideas for fixes. Any help would be much appreciated. Thanks!
(3,248 Views)
Hi Coulton,
you append new data always to the end of the array. Maybe you should prepend new data in front of the array?
(3,241 Views)
Accepted by Coulton
Change the property of the x-axis to "inverted".
(3,232 Views)
Perfect. Thanks!
(3,226 Views)
