Labview Integration
The current project has a requirement to use the velocity curve to integrate the time axis to calculate the displacement. I used the integral function inherent in Labview to do the test, and the result obtained was not the theoretical value. For example, the integral of a single periodic sine wave with a amplitude of 1 using 1D Numeric Integration.vi was 0.6366, which is not a theoretical value of 2. What is the reason? What exactly should I do to compute the displacement by integrating the velocity curve with respect to the time axis? Thank you very much!
(2,498 Views)
Your descriptions is insufficient. What is dt? What are the units? What integration method?
(0.6366 is approximately 2/pi, something to think about. My guess is that dt is wrong)
It would be significantly easier to help if you could attach a simple VI to show what you are doing? Please do so! Thanks!
(2,487 Views)
